This indicates a misconfiguration between routers on a locally attached subnet.
Check the configuration on appropriate routers and make any configuration updates as needed. Locally, configuration can be verified by issuing a 'show router-discovery <vlan-name>'. Configuration can be corrected by the 'configure <vlan-name> router-discovery [add|delete] dnssl <dns_suffix>' command.
Warning
Received Router Advertisement on vlan %vlanName% from %otherRouter% with a DNSSL Option Length of %optLen% which is less than the minimum required length of %minLen%
| Name | Type |
| vlanName | VLAN |
| otherRouter | IPv6 |
| optLen | uInt |
| minLen | uInt |
